Strange Noises
Dave Jackson
- Car Details: Lotus Elise S1 Red
I have an Elise S1 and I seem to have developed an alarming metallic noise when the engine gets very hot after a long run. Yes I know they all have quaint strange noises, but this one sounds like the engine is going to fall out whenever I go over the slightest bump in the road!!! Give it 10 minutes to cool down and all is back to normal. Has anyone any clues or suggestions.
- Matt R
- Car Details: Azure Blue S1 Elise
Hi Dave, Welcome to NYLOC
So the car is fine on bumps when it's cold ?
can you describe the noise a little better ? is it engine related ?
Lets celebrate the birth of Santa! No, wait. That's not right. Whose birthday is it again?
- MartL
- Car Details: That Bright Green Honda'd S2 Exige
Sounds like the rear toelinks/suspension bushes getting hot and creaking - it gives a kind of metallic clunk, similar sound to if an exhaust on a regular car was knocking/squeeking against something?
Nearside sussy mount/toelink come pretty near near the exhaust, and grease in them tends to dry out over a period of years? Newer cars have a heat shield fitted in these areas.
Only makes the sound when hot...
Happened on my S2 elise
Mart.
Mart.
Dave Jackson
MartL wrote:Sounds like the rear toelinks/suspension bushes getting hot and creaking - it gives a kind of metallic clunk, similar sound to if an exhaust on a regular car was knocking/squeeking against something?
Happened on my S2 elise![]()
Mart.
I think and hope your right. Someone has suggested I change the bushes!
Thanks
- Matt R
Check the toelinks as well
You used to be able to buy a heatshield but I can't see it on the eliseparts website anymore...
Dave Jackson
Hi MattMatt R wrote:Hi Dave, Welcome to NYLOC
The noise was just as someone else described, like a knocking/squeaking on the exhaust. The car has been in the South Of France and there it does get HOT, where it did make the same noise but not as bad. I drove it back on Monday and coming over the speed bumps in my road I thought the engine was about to fall out!!!! 10 minutes later, no problem all quiet! Someone else mention bushes to me when I had Bilstein shocks fitted recently. They make an awesome difference and they are very reasonable from Lotus.
I will look into replacing the bushes and look for a heat shield.
Thanks for the reply, much appreciated
yasmar
- Car Details: Stolen by the state.
DSB wrote:my flexi pipe on my exhaust used to make such a noise when hot.... turned out it had broken
prob no help but just my
oooooo nooooooo
