I know its only fun until he sends an injunction
i need some advice please - I'm gutted
It is hopefully getting moved down monday or tuesday next week. It's not drivable so it has to come by flat bed. Then i need to get over there and pay it a visit.
Thanks for the advice and recommendations fellas. The car means an awful lot to me and i'm pretty precious about it.
Paul H
- Car Details: Yellow SubmarElise
It might not be the best time to mention it but there are a few jobs you might consider as extras whilst the clam is off:
New radiator
New radiator fan
Towing eye post
New (proper) horn
HID lights
New light brackets
New radiator
New radiator fan
Towing eye post
New (proper) horn
HID lights
New light brackets
Yorkshire: the right side of the Pennines
yasmar
- Car Details: Stolen by the state.
Paul H wrote:It might not be the best time to mention it but there are a few jobs you might consider as extras whilst the clam is off:
New radiator
New radiator fan
Towing eye post
New (proper) horn
HID lights
New light brackets
Good thinking....I had each one done individually everytime its been into the bodyshop
yasmar
Get on with it then.....something to get your tooth intoPaulT wrote:Easy tiger, we've only got 5 gigs of hostingSimonE wrote:Of all the bodyshops you have used to dateyasmar wrote:Central is good locally or if you want a really first rate job Sinclairs (Essex Motorsport) in Romford.
- which would you recommend?
I would not bother with the radiator unless you are upgrading to an alli one.
The others are worth while and quite cheap
If you do not go for HID's, Osram Nightbrakers are very good (I put these in our lasses full beam lights to match her HID's)
I've got the HIDS already. Great Mod.
Towing eye and rad are on the list but I'm not to bothered about taking the clam off myself so I might have to wait until I've saved up the cash for the other bits.
If it is repairable then it is very likely to come out of Central better than when I had it in the first place! I'm going to see if I can get the hardtop resprayed and a new windscreen put in
You can fit the horn with the clam on (just pull back the o/s wheel arch liner and remove the front under panel) having said that a good one is only about £15 (form halfrauds), drivinglight brakets are about the same form elise shop etc.
If you fancy an upgrade you could go for the 111s driving light brakets and then just the cheese grater grill
(also shows the stainless towing bracket)
NB the grills are about £300
Re the hard top and windscrean, they will not be a problem and worth doing at the same time, I have used their screen fitting guy for years on my fleet vehicles (he also did my elise when it had the new front end)
(also shows the stainless towing bracket) NB the grills are about £300
I popped up to Central and spotted yours, I didn't realise you already had an 111S so no worries re the grill etc (although you do need a new one).
From a quick look it does not look all that bad (mine was a lot worse), clam, headlight covers, driving light bracket and grill (I did not check the screan was that hit by the clam?)
** update **
Central have removed the clam. I've spoken to the inspectors from the insurance company and they have asked central to provide a quote for repair. initial estimate is £5k!
Insurance inspector said that it should be repaired all day long at that.
I really hope so!
I really hope so!
Clams will be more than half of the amount. New front clams are over £2700 ATM and even lotus don't have any - serious back order problem
Sounds like a wheel took a bit of the brunt so there might only be one side of the suspension and steering included in that cost. If it was a platic capped rad I would expect it to have stress fractures and need a replacement - but you won't know that until it had the hose replaced and brought upto pressure
If you've got away with £5k I would say it wasn't a particularly big'un
Good luck and hope all turns out okay
Let's all be careful out there folks !
Dave Pollard
