New owner! First breakdown..!
oli748
hesslenaylor
Car Details: Elise 220 Sport Metallic orange
Hi if the car has been laid up for a long time the rubber has become tired, it also sounds like the fans need checking out, all the same thing not been used for a long time.
If you look on Seloc wiki tec I think it is called you should be able to get the part number.
I am sure more advice will follow :up
Mark from Hessle
oli748
hesslenaylor
Sorry to say but to get to the fan the front clam has to come off
oli748
hesslenaylor
Keep in touch and post up how you get on, get yourself to Buckles for lots of advice no cost lots of nice people.
Mark :bravo
oli748 wrote:MK1 Focus RS
:bravo Never owned one but love 'em :D
Welcome to the forum, good choice of car :wavey
softlips
Car Details: Currently Lotus less
Sounds like the fan came on as it should. What did they sound like? They can't get the temp down if there is no coolant to cool. They wouldn't normally come on while driving as the airflow will do the cooling.
It may be worth replacing the expansion tank cap. These often fail (but usually by leaking) but I guess the valve could seize causing high pressure. I've heard of that hose going before - I hope that's your only problem.
Please change the expansion tank too, or at least clean it - I hope that colour is from the previous HGF. No sign of Mayo I hope!
I'd give it a real good flush through after changing the hose, fill with water and see if all is OK at running temperature, If it is, drain again and fill with coolant then do the oil etc.
oli748
softlips
If you're swapping the stat it may be worth fitting a PRRT instead. The stat on the S1 is a real PITA to get to and get out.
oli748
softlips wrote:If you're swapping the stat it may be worth fitting a PRRT instead. The stat on the S1 is a real PITA to get to and get out.
th4neuk
Car Details: Sport 160
Hi oli,
Welcome to the fray.
Gutted it's died so early on but should be fixable. Give us a shout if you need a hand :-)
Alan
Alan Croft
2000 V8 GT Esprit sold :-( :-(
87 Turbo Esprit HC sold :-(
2000 Elise Sport 160
JP Formula 3 race car :-)
1960 mk1 mini
oli748
th4neuk
No probs.
Mark aka hesslenaylor was a great help when we stripped my front clam off to fit a new rad so done that one already.
One good bit of advice is soak every nut/bolt/fixing in wd40 days before you go near it! Lotus used the cheapest nastiest bolts you ever saw and they were rusting before they were eve fitted to the car, you eve look at one wrong and it will shear itself and fall off lol.
All part of the fun though.
Btw are you going to the meet a week on Tuesday. Even if the car isn't running be good to come along and meet everyone and also sort your membership out lol.
Alan
Alan Croft
1960 mk1 mini
oli748
