New owner! First breakdown..!
th4neuk
Car Details: Sport 160
I sense a spanner party at oli and Sarah's house lol.
Hope the bacon buttons and tea are in plentiful supply :lol
Btw even though the car is being a typical loti are you still going to the buckles next Tuesday?
Alan
Alan Croft
2000 V8 GT Esprit sold :-( :-(
87 Turbo Esprit HC sold :-(
2000 Elise Sport 160
JP Formula 3 race car :-)
1960 mk1 mini
oli748
Sooty
oli748 wrote:Right lads I'm thinking of taking on replacing the head gasket my self, I'm fairly handy with the spanners,
but haven't taken on anything of this magnitude before is there any how to guides anywhere? Parts wise i know i'll be needing this
http://www.eliseparts.com/products/show ... asket-set/" onclick="window.open(this.href);return false;
http://www.eliseparts.com/products/show ... king-tool/" onclick="window.open(this.href);return false;
and im guessing the multi layer steel head gasket is the one to go for.
Then when i've got the head off take it to my local machine shop for them to have a good look at it to check out the integrity of it.
then when im putting it back together im guessing it would be a good idea to get a set of these
http://www.eliseparts.com/products/show ... -bolt-set/" onclick="window.open(this.href);return false;
So...what am i missing? am i being over ambitious? Im in no rush to get the car back on the road and can take my time with it.
Cheers,
Oli
Some oil and some water would be useful too :D
Joff
Car Details: S1 Elise Shed, S2 Exige
did somebody say bacon?... I sensed Bacon.....
When reading the thread and seeing the temp it got to and the result I knew where this was going! the last time I had that behaviour it was because the thermostat had jammed leaving a short coolant circuit, leading to overheating and catastrophic HGF. I even had the sludge dripping out of the side scoops!
and that was with a PRRT thermostat! don't know what that was about. Head gasket changes aren't brain surgery, but they're bleedin awkward, I take the clam off to make life easier. The landrover headgasket's a two piece Item, and you'll probably be able to find heated discussions about whether it's the best option or not elsewhere on the Web. Last thing I saw was that they were the best option if the liner heights are a bit uneven, but possibly dont have as much clamping force as the original type so could be more susceptable to fail in big power conversions.(proper big, not 135/160 big) .
I've used the landy multi-layer system ones before and not had any problem with them. one did 7000 miles in a thrashed VHPD engine before I saw sense and sold it.
......It's time to start the Music, it's time to light the lights....
felix
Car Details: Elise S1 Dva'd !
if you change the head gasket, then make sure the liner height s are within tolerance - otherwise it may go again.
might be worth a call to Dave Andrews (DVA) - very clued up and happy to give advice + can supply parts if necessary.
http://www.dvapower.co.uk/" onclick="window.open(this.href);return false;
Fingers crossed you get it sorted...
Darren
oli748
hesslenaylor
Car Details: Elise 220 Sport Metallic orange
Hi. I will be free all next weekend as Carole is away in the sunshine, so give me a call if you need a hand :bravo
Let me know if you need any extra tools or anything.
Mark
