Hi Guys,
Relatively new '06 Exige S2 owner here - not had chance to make it to any of the meets yet but hopefully will do soon!
I've got an issue with my speedo/ABS (basically neither work) and I've had a garage look at it but despite their best efforts they don't seem to be able to track the issue down. I've had a similar problem before and had both rear wheel bearings replaced which solved it but somehow it's come back. n/s/r bearing has been replaced again to no avail.
Their suggestion is to get it to a Lotus specialist who can plug in to the ABS controller which should give some more clues than a standard OBD reader does on the ECU - so does anyone know of anywhere around Harrogate who can do this? Foulds seem to get good reviews but they're a bit of a trek, likewise Phoenix Motorsports. Pure Lotus are the obvious local candidates but I've had a few fairly unimpressive encounters with them so not particularly inclined to go back there if I can avoid it...
Cheers!
Lotus Specialist Harrogate
minisweeper
- Car Details: '06 Exige S2
JCT would be the only people local with real Lotus diagnostics for the ABS, NYLOC members get a discount.
What you could do though is clean up the toothed ABS rings on the hubs/driveshafts with a screw driver (I had an issue with some minor corrosion that 'narrowed' the gaps on a car, main dealer could not diagnose the issue but wanted to replace sensors, I sorted by doing this).
Also clean up the sensors while you are at it (being magnetic they can pick up debris that can confuse things).
- softlips
- Car Details: Currently Lotus less
The ABS rings sometimes corrode and the pressure underneath them can make them crack. I'd be surprised if this happened on a car at 7 years though.
A decent garage should have checked and cleaned the rings first though.
I did once have a car in which the ABS sensors were so sensitive that fitting a different make of tyres front - rear threw the ABS out. I was doing 45K a year in it so changed tyres regularly and twice when the company fitted a different pair the ABS played up.
Have you spoken to Chris Foulds about Italy. He's quite happy to give advise over the phone as are most of the other specialists.
- The Scotts
- Car Details: Exige s
Give Ian at lotus Newcastle a call one of his lads lives in ripon so maybe able to sort something out.
Martin and Dennis the op has an S2 and the speed/ABS ring
is part of the wheelbearing and you can't get to it to clean it.
You can put a meter on them to check to see if there ok
JCT would be the best place for you to go.
And suddenly I realised that I was no longer driving the car consciously. I was driving it by a kind of instinct, only I was in a different dimension. Ayrton Senna
Well that is a stupid idea fancy hiding them away so you can't fix it yourselfpearman00 wrote:Martin and Dennis the op has an S2 and the speed/ABS ring
- softlips
Cheers Tony.pearman00 wrote:Martin and Dennis the op has an S2 and the speed/ABS ring
