Hi all, just to see hello.
Just sold my OMS 2000 m single seater and got myself a Elise S2 on a 05 plate.
Spec.
It's running 209 bhp. It has a lot of work done.
DVA VPHD engine
Fully balanced and rebuilt with fully hardness tested head
New everything from liners to bearings and Omega pistons
Ported head
Polished crank
Bigger inlet/Exhaust valves
Uprated valve springs
Goetze liners
Remote stat
Emerald ECU with loom adapter not splice and dice
Oil temp and pressure gauges
Shift light system
Throttle bodies
Dyno printout showing 209BHP
Lightened flywheel
Baffled sump
Full exhaust system
Quantum single ways 400/500 with helpers
Team dynamics with pretty fresh AO48s
Torsen LSD
Sparco snap off wheel
Hardtop
Braided hoses
So far I've fitted.
Saftey device Aframe cage and petty bar
Corbeau seats
Schroth harness
Nitron rose bushes
New ball joints
New track rod ends
Race gear cables
That's a start. Lol
Cars going to be used for Harewood hill climb and sprints at Blyton. And a few road miles for fun..
Newbie here.
Paul Martin
- Car Details: Elise S2
- Attachments
- image.jpeg (90.86 KiB) Viewed 11306 times
- Doug
- Car Details: S4 Elan, S2 Elan & Scruffy
Welcome to the club Paul
Are you local ? Pop along to the 26th January meeting at The Buckles if you can, would be good to see you and your car.
Doug
Doug
Old Lotus don't die they get fixed and if it cannot be fixed with a BIG hammer then you have an electrical problem.
Hi there and welcome, what did your car start as I presume a k-series but a 111s or 118bhp?
What pads are you running (brakes not mentioned on the spec)
Paul Martin
Started as a 111s not sure on power then. It was a track day toy for the last owner.Dennis wrote:Hi there and welcome, what did your car start as I presume a k-series but a 111s or 118bhp?
It's running AP 4 pots on the front and AP Disks with std calliper so rear. Not look at the pads yet. That's this weeks jod when I rebuild the suspension back up...
Doug. Where's the Buckles ?
- deggles
- Car Details: S1 Exige #406, Alfa Romeo 4C
Car sounds awesome, 209bhp from a VHPD is some going!
The Buckles is on the A64 just near York, more details on the main homepage if you scroll down: http://www.nyloc.org/
- El-ahrairah
- Car Details: Aspen White Exige S
Welcome
As others have stated. Bring along to Buckles in new year for us to have a peak at the engine bay
Paul Martin
Might just do that.
- Steve&Janey
- Car Details: LOTUS ELISE S2 DVA K13
have you had the engine done by DVA or was it already done. Ive just got a ported head big valves and cams off DVA (150hp) . Cant wait to put it on.Paul Martin wrote:Hi all, just to see hello.
Spec.
DVA VPHD engine
Ported head
Polished crank
Goetze liners
Remote stat
Shift light system
Throttle bodies
Lightened flywheel
Baffled sump
Full exhaust system
Torsen LSD
Hardtop
Braided hoses
So far I've fitted.
Corbeau seats
Schroth harness
Nitron rose bushes
New ball joints
New track rod ends
Race gear cables
That's a start. Lol
Paul Martin
It was done by the last owner. I have a dyno print out at 209 but I think that might be a bit optimistic
lol
I'll get the map checked at Day Tuner by Damian before I race it up the hill or track.
- PaulT
- Admin Team
- Car Details: 250 Cup
Welcome aboard - spec looks great and that'll be from one of the last few months' of production of 111S I should think.
Yeah bring it along in Jan, the meeting's on the 4th Tuesday (as ever) so that makes it the 26th.
Paul Martin
Hi, one thing I've found is that the front alloy under tray is missing. Big ask but is there some one local that would let my make a template of it so I can make one ?
- El-ahrairah
Where are you based/local to?
Paul Martin
I'm base near Pocklington near york.
