I actually just need the spacer (part 5, A111H0025S in the diagram) to make everything fit using the original hub.
Thanks!
Dan
Fab, I think around 20mm ideally but not too fussed as long as the holes line up, which is my problem at the moment!Ishy wrote:Think I might have one, depending on which depth you want they come in different depths 15, 20, 25, 30mm think two depths from Elise Parts & the other two from Elise Shop
Yes I'm at Buckles, will have a look what I have that is useable as I machined some of mine to use for something else (cant remember what now) think I may have a 15mm one you can have..deggles wrote:Fab, I think around 20mm ideally but not too fussed as long as the holes line up, which is my problem at the moment!Ishy wrote:Think I might have one, depending on which depth you want they come in different depths 15, 20, 25, 30mm think two depths from Elise Parts & the other two from Elise Shop
Hadn't realised compatible spacers were available from eliseparts/eliseshop to be honest, I'd only seen their full removable kits
Are you at Buckles next week?
Thanks Dennis, sounds like Ishy can sort me one but I'll let you know if not (save you a trip up to the loftDennis wrote:I might have a spare in the loft
