Wanted - Elise Coolant hoses
9x size 40 (30 - 40mm)
9x size 45 (35 - 45mm)
Safely tucked away for you :bravo
Joff
Car Details: S1 Elise Shed, S2 Exige
Cheers Matt.
Tony, if you have got those hoses left after your conversion I could help clear out your garage a bit. In fact, if you've got the ali tube as well, maybe you want rid of the lot, effectively the outlet from the engine down to where it connects to the pipe in the o/s sill, that'd be good.
Joff
......It's time to start the Music, it's time to light the lights....
pearman00
i go out and put them all in a bag for you just let me kown
what to do with them
Doh, forgot to pick up the bits from Humberside Airport :homer
Joff
Cheers Matt, found them on the door mat.
Tony, are you going to the buckles next Tuesday?
