Strange Noises
Posted: Thu Jul 09, 2009 3:59 pm
by Dave Jackson
I have an Elise S1 and I seem to have developed an alarming metallic noise when the engine gets very hot after a long run. Yes I know they all have quaint strange noises, but this one sounds like the engine is going to fall out whenever I go over the slightest bump in the road!!! Give it 10 minutes to cool down and all is back to normal. Has anyone any clues or suggestions.
Re: Strange Noises
Posted: Thu Jul 09, 2009 5:24 pm
by Matt R
Hi Dave, Welcome to NYLOC
So the car is fine on bumps when it's cold ?
can you describe the noise a little better ? is it engine related ?
Re: Strange Noises
Posted: Thu Jul 09, 2009 7:13 pm
by MartL
Sounds like the rear toelinks/suspension bushes getting hot and creaking - it gives a kind of metallic clunk, similar sound to if an exhaust on a regular car was knocking/squeeking against something?
Nearside sussy mount/toelink come pretty near near the exhaust, and grease in them tends to dry out over a period of years? Newer cars have a heat shield fitted in these areas.
Only makes the sound when hot...
Happened on my S2 elise :up
Mart.
Re: Strange Noises
Posted: Fri Jul 10, 2009 7:07 am
by Dave Jackson
MartL wrote:Sounds like the rear toelinks/suspension bushes getting hot and creaking - it gives a kind of metallic clunk, similar sound to if an exhaust on a regular car was knocking/squeeking against something?
Mart.
I think and hope your right. Someone has suggested I change the bushes!
Thanks
Re: Strange Noises
Posted: Fri Jul 10, 2009 7:08 am
by Matt R
Check the toelinks as well :bravo
You used to be able to buy a heatshield but I can't see it on the eliseparts website anymore...:(
Re: Strange Noises
Posted: Fri Jul 10, 2009 12:32 pm
by Dave Jackson
Matt R wrote:Hi Dave, Welcome to NYLOC
Hi Matt
The noise was just as someone else described, like a knocking/squeaking on the exhaust. The car has been in the South Of France and there it does get HOT, where it did make the same noise but not as bad. I drove it back on Monday and coming over the speed bumps in my road I thought the engine was about to fall out!!!! 10 minutes later, no problem all quiet! Someone else mention bushes to me when I had Bilstein shocks fitted recently. They make an awesome difference and they are very reasonable from Lotus.
I will look into replacing the bushes and look for a heat shield.
Thanks for the reply, much appreciated
Re: Strange Noises
Posted: Fri Jul 10, 2009 10:50 pm
by DSB
my flexi pipe on my exhaust used to make such a noise when hot.... turned out it had broken
prob no help but just my :10p
Re: Strange Noises
Posted: Sat Jul 11, 2009 9:30 am
by yasmar
DSB wrote:my flexi pipe on my exhaust used to make such a noise when hot.... turned out it had broken
oooooo nooooooo :dsb and his :10p
:judge
