Lotus Specialist Harrogate
Posted: Sun Jan 12, 2014 10:01 pm
Hi Guys,
Relatively new '06 Exige S2 owner here - not had chance to make it to any of the meets yet but hopefully will do soon!
I've got an issue with my speedo/ABS (basically neither work) and I've had a garage look at it but despite their best efforts they don't seem to be able to track the issue down. I've had a similar problem before and had both rear wheel bearings replaced which solved it but somehow it's come back. n/s/r bearing has been replaced again to no avail.
Their suggestion is to get it to a Lotus specialist who can plug in to the ABS controller which should give some more clues than a standard OBD reader does on the ECU - so does anyone know of anywhere around Harrogate who can do this? Foulds seem to get good reviews but they're a bit of a trek, likewise Phoenix Motorsports. Pure Lotus are the obvious local candidates but I've had a few fairly unimpressive encounters with them so not particularly inclined to go back there if I can avoid it...
Cheers!
Cheers!
