Wheel spacers Yes or no.??
Posted: Tue Oct 21, 2014 8:11 pm
by Steve&Janey
Thinking of changing my rimstock alloys on s2 k series, but seems you need wheel spacers for rears if you fit exige y type spider alloys, Cant even get aftermaket rims without using spacers.
Not sure i like idea of a 20mm thick alloy rim holding my rear wheels on.?
anyone used them.?
Re: Wheel spacers Yes or no.??
Posted: Wed Oct 22, 2014 7:59 am
by softlips
I've always been very suspicious of them personally.
Posted: Wed Oct 22, 2014 5:56 pm
by Si_F
polarexpressed wrote:Thinking of changing my rimstock alloys on s2 k series, but seems you need wheel spacers for rears if you fit exige y type spider alloys, Cant even get aftermaket rims without using spacers.
anyone used them.?
Hub centric spacers are fine, not cheap but if you have to use a spacer then this is the type to use.
Posted: Wed Oct 22, 2014 8:10 pm
I have used hubs enteric spacers before, get some quality items from someone you trust and there should not be an issue.
Posted: Thu Oct 23, 2014 4:00 pm
by Mark H
Been using these for years with no issues both on the road and track:
http://www.eliseparts.com/products/show ... pacers-s2/" onclick="window.open(this.href);return false;
Posted: Fri Oct 24, 2014 8:27 am
by MartL
Mark H wrote:Been using these for years with no issues both on the road and track:
So have I - No issues - actually make popping the wheels on and off easier, having studs to slide the wheels onto, instead of the OEM nuts.
Posted: Fri Oct 24, 2014 7:08 pm
by albutch
Me too.
