Wishbone and suspension overhaul on S1
Posted: Tue Jun 23, 2015 7:33 am
by S1ben
Hi Fellas,
I removed the front of the car to replace the radiator and the suspension is completely shot!
I know that 'Google is my friend'; but i just wanted to ask you guys if you could recommended somewhere other than Elise Parts to source a full set of wishbones for an S1 Elise,
http://www.elise-shop.com doesn't seem to have them
http://elise-spares.com don't seem to do s1 wishbones
Do you know anywhere else i could try?
Cheers,
Ben
Re: Wishbone and suspension overhaul on S1
Posted: Tue Jun 23, 2015 10:42 am
by MartL
How do Ben...
That's a fairly typical view of a UK, 15 year old Elise I'm afraid! The salt and winter weather tend to make the components look like they went down with the Titanic!
Have you considered a refresh, as opposed to replacement? I did that with my S2 (..which led to a K20a swap too!
Lots of info out there - basically, you're looking at stripping them down, having them blasted/cleaned (you'd be surprised how well they look after the surface rust is removed) an them zinc passivated(?) and/or powder coated / POR15'd.
You can see how mine turned out in the lower part of this pic from my Honda build thread: They looked very similar to yours pre-strip down - I had them blasted and powder coated, followed by a coat of clear POR15, with replacement of all bushes and bearings too
Edit: Just recalled that I started a thread abuot mine Ben - some pics of the 'befores' there... Never did get round to finishing it! I was rudely interrupted by a catastrophic engine failure, and subsequent Honda install! Being honest.. I've still not done the front wishbones!!
viewtopic.php?f=25&t=18596
Posted: Tue Jun 23, 2015 4:45 pm
by softlips
As Martyn says they should be OK if blasted and recoated.
While you have them off change those Koni's too.
Posted: Wed Jun 24, 2015 2:15 pm
by Byron
Either from jct 600 parts.
Or dave at
http://www.seriouslylotus.com/..
DISCLAMER: LOOKING AT HIS SITE WILL CAUSE YOUR SPENDING TO INCREASE..
Posted: Thu Jun 25, 2015 10:04 am
by wabbitkilla
As others have said, have you considered getting them blasted, coated, and new bushes and balljoints fitted?
I know i replaced all of mine and it was an expensive experience ... mine were in the same state and the rears a little out of shape.
I intend to pop them into a friendly specialist and ask their opinion of whether they can be salvaged?
Posted: Fri Jun 26, 2015 9:29 pm
There was a thread on seloc the other week of a place local to us (n yorks) that did the blasting and re coating and the price seemed very reasonable, I will see if I can find the thread
Posted: Fri Jun 26, 2015 9:39 pm
Posted: Sat Jun 27, 2015 7:07 am
by softlips
I must have missed that thread, not worth doing them yourself for that cost.
Posted: Sat Jun 27, 2015 8:47 am
That was my thought (as posted) pity about the timing....just after I had done mine by hand, I must have spent £100+ on por15, wire wheels! paint brushes, materials to hang the wishbones whilst painting/drying, never mind my time
When you do your refresh, seriously lotus are great for bits, I did all ball joints, bushes (I went for overkill rose joints) along with dampers etc (they are NTR 40's but nss2's are quite a bit cheaper, almost as good, ideal for street use and trackday and also rebuild able.
I also did the wheel bearings (when you have everything off it seems stupid not to do these)
I think Dave has a kit including nitron NSS2, bushes and bolts for a very good price and his service is great
If you are going to bin you koni's I will have them (don't know hy I just want a set to keep in the garage (I collect bits of cars, have a few racing tyres and a bump as a 'feature' in the back garden
Posted: Sat Jun 27, 2015 1:54 pm
by softlips
What is this bump you've made a feature of Dennis?
Posted: Sat Jun 27, 2015 10:52 pm
Sorry bumper (including defuser) when I say feature the tires are lined up (NASCAR, STM & btcc including a care damaged rim) and the bumper (from a 360 GT car, damaged during a race at donington), was hung above them (before the conifers were cut down
Posted: Thu Jul 02, 2015 10:35 am
by chiark
I had my rear wishbones and uprights blasted, passivated and lacquered at Allenchrome last month. Was warned it might take 2 weeks, but they were turned around in a few days.
Results are superb. really happy with them. Mine is a year 2000 S1, and they weren't as badly corroded as yours, but they came up brilliantly.
I also replaced bushes and ball joints (SeriouslyLotus), toe links (Spitfire), wheel bearings (Timken), and brake discs&pads. I can probably put some pics up if people are interested
. There's a thread of lessons learned in my garage post on seloc.
Unfortunately I was in Munich on Tuesday otherwise I'd have come along to Buckles. Hopefully might make it in July!
Cheers, Nick.
Posted: Thu Jul 02, 2015 9:05 pm
by Nyloc 1
Great to see Allenchrome doing well, we were one of their first customers when I worked for a Scarborough switchgear company.
Posted: Fri Jul 03, 2015 9:44 pm
chiark wrote:I had my rear wishbones and uprights blasted, passivated and lacquered at Allenchrome last month. Was warned it might take 2 weeks, but they were turned around in a few days.
Cheers, Nick.
Please DO NOT post any picture as it will really annoy me how much better your will look compared to mine
