1992 Esprit se turbo rear brakes
I have just replaced the rear brake pads on the esprit and freed off one of the front calipers which had seized.After bleeding the system all appears ok and the handbrake works well. My prob is that when I apply the foot brake the hand brake light comes on then goes off as the car slows down. Is there an adjustment for this or have I missed something ?Any suggestions please.
I would check the fluid level first, may be as you slow, if the level is low and the fluid flows forward the float drop making the light come on?
I am guessing on your car the only caused for the brake light yo cone on are the handbrake, the fluid level and pad ware
Thank you Den, will check fluid level as pads are definately ok.
