S2 Elise ECU
Posted: Mon Jul 15, 2024 8:26 pm
So this is a long shot being a new member.
I have a 2004 Elise 111s with the 160 ecu. I have an intermittent fault with the engine cutting out and then cranks over but the fuel pump does not prime. It usually re starts after half an hour to an hour. It runs fine normally but obviously I don't have the confidence to go far in it. It's very frustrating.
Chris Foulds at Honley has been investigating but cannot pinpoint the problem as it usually doesn't have the fault when he has the car. So far we have disconnected the immobiliser, new fuel pump, new multi function relay. The next stage is replacement ecu.
Before we do this (this is the long shot bit) does anyone have a 160 ecu either for sale, or if anyone has a 111s could I borrow the ecu to test on my car (send to Chris Foulds so you know I am genuine if you prefer) to rule in or out an ecu fault. Any replies greatly appreciated.
