Thinking of changing my rimstock alloys on s2 k series, but seems you need wheel spacers for rears if you fit exige y type spider alloys, Cant even get aftermaket rims without using spacers.
Not sure i like idea of a 20mm thick alloy rim holding my rear wheels on.?
anyone used them.?
Wheel spacers Yes or no.??
- Steve&Janey
- Car Details: LOTUS ELISE S2 DVA K13
- Si_F
- Car Details: Back in a silver plastic car...
Hub centric spacers are fine, not cheap but if you have to use a spacer then this is the type to use.polarexpressed wrote:Thinking of changing my rimstock alloys on s2 k series, but seems you need wheel spacers for rears if you fit exige y type spider alloys, Cant even get aftermaket rims without using spacers.
anyone used them.?
Formerly known as S1mon
I have used hubs enteric spacers before, get some quality items from someone you trust and there should not be an issue.
- Mark H
- Car Details: S2 Motorsport Bodied Elise - SC/CC Honda
Been using these for years with no issues both on the road and track:
http://www.eliseparts.com/products/show ... pacers-s2/" onclick="window.open(this.href);return false;
Mark
- MartL
- Car Details: That Bright Green Honda'd S2 Exige
So have I - No issues - actually make popping the wheels on and off easier, having studs to slide the wheels onto, instead of the OEM nuts.Mark H wrote:Been using these for years with no issues both on the road and track:
