seat removal
Posted: Fri May 29, 2009 11:58 am
by Landy
Hi
Quick question
I've been thinking about carpeting my S1 out and just have a question about removing the seats
Am I right in thinking that unscrewing the seat runner bolts is as simple as it sounds,
I'm not going to unscrew the bolt and hear the other end drop am I? Is it a nut and bolt or just a bolt that fastens to the floor pan?
I'm not very hands on with the car so apologies if its a dumb question
Re: seat removal
Posted: Fri May 29, 2009 12:40 pm
by SkipperMac
My understanding is that there is some sort of captive nut so you shouldn't have a problem. One of mine was loose and when I mentioned it to Danny at Pure Lotus he just tightened it up without needing to get underneath.
Re: seat removal
Posted: Fri May 29, 2009 2:14 pm
by 999w
I have just fitted carpets to my newly-acquired S2 and it was quite a straight-forward job, if a little fiddly getting to all the bolts. No loose nuts to worry about, though.
And I must say that the car was very comfortable on my 500-mile trip at the weekend, to which the carpetting contributed.
Re: seat removal
Posted: Fri May 29, 2009 6:55 pm
by Matt R
Rivnuts in the floor so you can undo them no problems
Don't stick them down with anything or you may get ali corrosion issues, like the recent footwell notice
you'll also have a nightmare getting to the rear left pax seat bolt, you need a really long ball ended allen key
p.s. carpets
Re: seat removal
Posted: Fri May 29, 2009 6:59 pm
by Moggy
Makes it easier if you have a socket set that includes allen bits and a long extension even for the easier to reach bolts
Re: seat removal
Posted: Fri May 29, 2009 8:16 pm
by PaulT
You don't *need* a ball ended allen key but it will help. I think I used a regular allen key and a ring spanner then a bar to turn the spanner - you can improvise. It's not a difficult job, it would be a doddle with a 24" allen key!
