Hi I have been having problems with dashboard lights and resetting while driving with the lights on!
It would appear that the problem has been solved by using the wives hairdryer to dry out invisible condensation from internals, I have also removed the silicon crystals from inside the dash and moved them away from the electrics.
Also found out that the spring clips that find it so easy to drop into the sill and so hard to remove once in can be recovered easily with the use of her dyson!
elise s1 dashboard
tangoed elise
- Visitor
- Car Details: 98r111
- Contact:
I put some tape on the springs so if it is loose it just hangs and clangs (I thought something important was about to fall off at first it made that much noise
Never had a problem with damp on/in the dash (touch wood)
