WANTED: Elise Horn Push (OE)
nigelh
Having changed the quick release system on my steering wheel this weekend I now find that the momo horn push I fitted with the old snap-off kit doesn't fit the new one. Tried to 'adjust' it to make it fit, but no joy.
I'm now looking for an OE horn push from an Elise - needs to be the type that has two spade connectors, and a fairly shallow body.
Anybody have one lying around?
I swapped the innard of my louts 'momo' push with that of a standard momo horn push with 2 spade connectors as the oe new were silly money
nigelh
Thanks Dennis, but I don't think that's an option with my new quick release unless there are different designs of momo horn push. The momo one that I have is deeper than the OE due to the 4 'legs' that stick out the back with the spring, and the extra depth seems to be what stops it fitting.
Pretty sure I need something that is no deeper than the OE horn push.
...although having said that, I'm basing this on a comparison between a Lotus badged momo which I just butchered to try to make it fit, and my original OE Lotus one which I butchered when I fitted my original snap-off kit about 10 years ago!
EDIT TO ADD: Based on your suggestion Dennis, I've ordered cheap Sparco & OMP horn pushes to see if either will fit and take the lotus centre.
