oli748
UKTony135
Car Details: Elise S2 135 S
http://www.ebay.co.uk/sch/i.html?_nkw=h ... &_osacat=0" onclick="window.open(this.href);return false;
Mark H
Car Details: S2 Motorsport Bodied Elise - SC/CC Honda
When I was living and working in York, we used: http://www.fastpack-york.co.uk/" onclick="window.open(this.href);return false;
Great company if you need any fasteners.
Mark
hesslenaylor
Car Details: Elise 220 Sport Metallic orange
Hi are you sure they are 35 long :?: and not 30
The bolt should be on the anvils to the left ( the longer ones )
It depends where you have the zoro set, remove the bolt and close the calipairs and see if it reads zero.
Just a thought
hesslenaylor
Sorry it would make them 40 long
Mark
hesslenaylor
Hi Oli
Right when measuring any bolt or cap head the length is from under the head to the end of the bolt. So use the deph gauge part to get the length, but make sure when gauge is closed up it reads zero first. Failing all that give me a call.
Mark
oli748
As a non-spannery person, would I be stating the obvious if I said have you tried buying the bolts from Lotus? Feel free to shoot me down in flames if they're £100 each / obsolete but with engine stuff I'd have thought it was quite important to get exactly the right one.
Anyway, good to see you having a go at this yourself, I've watched people do mine :homer
th4neuk
Car Details: Sport 160
Have we got a rover specialist in hull at all? Be cheaper than lotus probably.
I know there is the rover breakers down English street way I think if worst happens?
Alan
Alan Croft
2000 V8 GT Esprit sold :-( :-(
87 Turbo Esprit HC sold :-(
2000 Elise Sport 160
JP Formula 3 race car :-)
1960 mk1 mini
Mark H
Not sure which ones you need, but this is a good site to order your parts online: http://www.deroure.com/partinfo.asp?MAK ... PBID=36780" onclick="window.open(this.href);return false;
I have used them in the past as its cheaper than the fuel to the nearest dealer.
Mark
ad111s
Car Details: Exige 350 Sport
Is it part 5 here
if so its Part No A111E6160S £1.17ea
oli748
th4neuk
Might be worth ringing maple garage at sproatly.
Had some rover stuff from them before when my driveshaft seals failed
Alan
Alan Croft
1960 mk1 mini
oli748
