Are you needing someone to pop their car your way to stencil?
I'm 20 mins away from you in Howden.
Newbie here.
- El-ahrairah
- Car Details: Aspen White Exige S
Paul Martin
- Car Details: Elise S2
That would be fantastic. Or I could pop to you if the roads are to salty .
- El-ahrairah
I'm in most the day tomorrow or monday if you want to pop round. Not sure what you require though in the way of needing the car raised off the ground to stencil?
I would assume it needs to come off to stencil a new one, on the S1 the front is hidden by the front clam.
Have you contacted the likes of junks on seloc to see if he has one?
Paul Martin
They all seem to be around £70 to £150 ! I do fabrication so should be easy with a panel to copy.
Ouch, I though they would be cheaper than that, there again I suppose they get damaged quite often in frontal bumps.
Had another thought, can't you work it out by laying on your back, it should be obvious where it goes/fastens, granted copying one off the car will be easier but if not possible....
Paul Martin
Kindly sorted now .. Cheers el-ahrairha..
Paul Martin
Massive thanks to Mike for letting me remove his front panel front his lovely S2. Patern all done.
Nice to meet you and if you need any help just shout.
- El-ahrairah
Not a problem Paul, happy to help.
Hope the fabrication goes well and hopefully see you in January.
Paul Martin
Well it's been a busy couple of months.
Strip suspension and powder coat all the arms.
Fit Nitron bushes
Zinc plate hubs and bits
New ABS wheel bearings
Ball joints
Track rod ends
Seats
Saftey device roll with petty bar
Rear tow/ under brace
Race gear cables
First test at Blyton in March before Hillclimbing season starts.
Fit Nitron bushes
Ball joints
Track rod ends
Seats
Race gear cables
- Attachments
- image.jpeg (3.43 MiB) Viewed 7722 times
- image.jpeg (2.29 MiB) Viewed 7722 times
- image.jpeg (1.01 MiB) Viewed 7722 times
- image.jpeg (112.9 KiB) Viewed 7722 times
- image.jpeg (3.45 MiB) Viewed 7722 times
Paul Martin
Cheers can't wait !
- El-ahrairah
Pop the car round to mine sometime when weathers nice on a weekend perhaps so I can have a gander?
Paul Martin
Will do would a nice test drive.
That looks great.
The wheel looks brilliant
However... Whilst the rear tow bracket looks great, will marshals really bother crawl right under to try and attach to that or just use a wishbone if you have an off
Also get some new P clips for the break hoses as they let you shiny bits down
