Newbie here.
Paul Martin
Car Details: Elise S2
Hi all, just to see hello.
Just sold my OMS 2000 m single seater and got myself a Elise S2 on a 05 plate.
Spec.
It's running 209 bhp. It has a lot of work done.
DVA VPHD engine
Fully balanced and rebuilt with fully hardness tested head
New everything from liners to bearings and Omega pistons
Ported head
Polished crank
Bigger inlet/Exhaust valves
Uprated valve springs
Goetze liners
Remote stat
Emerald ECU with loom adapter not splice and dice
Oil temp and pressure gauges
Shift light system
Throttle bodies
Dyno printout showing 209BHP
Lightened flywheel
Baffled sump
Full exhaust system
Quantum single ways 400/500 with helpers
Team dynamics with pretty fresh AO48s
Torsen LSD
Sparco snap off wheel
Hardtop
Braided hoses
So far I've fitted.
Saftey device Aframe cage and petty bar
Corbeau seats
Schroth harness
Nitron rose bushes
New ball joints
New track rod ends
Race gear cables
That's a start. Lol
Cars going to be used for Harewood hill climb and sprints at Blyton. And a few road miles for fun..
Doug
Car Details: S4 Elan, S2 Elan & Scruffy
Welcome to the club Paul :up
Are you local ? Pop along to the 26th January meeting at The Buckles if you can, would be good to see you and your car.
Doug :oldie
Old Lotus don't die they get fixed and if it cannot be fixed with a BIG hammer then you have an electrical problem.
Hi there and welcome, what did your car start as I presume a k-series but a 111s or 118bhp?
What pads are you running (brakes not mentioned on the spec)
Paul Martin
Dennis wrote:Hi there and welcome, what did your car start as I presume a k-series but a 111s or 118bhp?
Started as a 111s not sure on power then. It was a track day toy for the last owner.
It's running AP 4 pots on the front and AP Disks with std calliper so rear. Not look at the pads yet. That's this weeks jod when I rebuild the suspension back up...
Doug. Where's the Buckles ?
deggles
Car Details: S1 Exige #406, Alfa Romeo 4C
:wavey welcome Paul.
Car sounds awesome, 209bhp from a VHPD is some going! :love
The Buckles is on the A64 just near York, more details on the main homepage if you scroll down: http://www.nyloc.org/
Crouchy
Car Details: Primer Grey Exige V6
sounds like a bit of a track weapon. Im sure you will have no problem having fun in that thing.
Welcome :wavey
As others have stated. Bring along to Buckles in new year for us to have a peak at the engine bay :D
Paul Martin
Might just do that. :wavey
Steve&Janey
Car Details: LOTUS ELISE S2 DVA K13
Paul Martin wrote:Hi all, just to see hello.
Spec.
DVA VPHD engine
Ported head
Polished crank
Goetze liners
Remote stat
Shift light system
Throttle bodies
Lightened flywheel
Baffled sump
Full exhaust system
Torsen LSD
Hardtop
Braided hoses
So far I've fitted.
Corbeau seats
Schroth harness
Nitron rose bushes
New ball joints
New track rod ends
Race gear cables
That's a start. Lol
have you had the engine done by DVA or was it already done. Ive just got a ported head big valves and cams off DVA (150hp) . Cant wait to put it on.
:hit :hit :hit :hit :hit :hit :hit :hit :hit :hit
Paul Martin
It was done by the last owner. I have a dyno print out at 209 but I think that might be a bit optimistic :homer lol
I'll get the map checked at Day Tuner by Damian before I race it up the hill or track.
Welcome aboard - spec looks great and that'll be from one of the last few months' of production of 111S I should think.
Yeah bring it along in Jan, the meeting's on the 4th Tuesday (as ever) so that makes it the 26th. :up
Rick101
Car Details: Orange Exige 350
Hello,
Sounds like a fun car to drive!
Paul Martin
Hi, one thing I've found is that the front alloy under tray is missing. Big ask but is there some one local that would let my make a template of it so I can make one ? :woo
Where are you based/local to?
Paul Martin
I'm base near Pocklington near york. :wavey
