Wanted: Lotus motorsport steering wheel kit spacer
deggles
Car Details: S1 Exige #406, Alfa Romeo 4C
Bit of a long shot but does anyone have an original Lotus snap-off steering wheel kit they’d be willing to part with? I bought one ages ago off SELOC but turns out it wasn’t entirely complete/original when I came to fit it :(
I actually just need the spacer (part 5, A111H0025S in the diagram) to make everything fit using the original hub.
Thanks!
Dan
Think I might have one, depending on which depth you want they come in different depths 15, 20, 25, 30mm think two depths from Elise Parts & the other two from Elise Shop
deggles
Ishy wrote:Think I might have one, depending on which depth you want they come in different depths 15, 20, 25, 30mm think two depths from Elise Parts & the other two from Elise Shop
Fab, I think around 20mm ideally but not too fussed as long as the holes line up, which is my problem at the moment! :lol
Hadn't realised compatible spacers were available from eliseparts/eliseshop to be honest, I'd only seen their full removable kits :oops
Are you at Buckles next week?
I might have a spare in the loft
Yes I'm at Buckles, will have a look what I have that is useable as I machined some of mine to use for something else (cant remember what now) think I may have a 15mm one you can have..
deggles
15mm would work, that's what I have fitted at the moment (albeit a home-made one) and the driving position is OK. Cheers :up
Dennis wrote:I might have a spare in the loft
Thanks Dennis, sounds like Ishy can sort me one but I'll let you know if not (save you a trip up to the loft :lol)
Much appreciated chaps :bravo
